Hi!
Would be very helpful if we can have AppendPreset in supported in the API. No GUI or selections, just blunt append the entire preset and all its contents.
An alternative is a flag in the preset itself that instructs vMix to append when opened (if you dont want to extend the API)
The ideal solution is support for all Inputs with the Addinput in API, but I assume there is a reason for the limited support for adding complex inputs with that method.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
if you have a open preset shortcut with leaving the value empty it will actually ask for which preset and allow you to append ( if that helps for now )
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
