Dante Midas m32R and Vmix clicking/ pops
Joined: 5/12/2021(UTC) Posts: 1  Location: Los Angeles
I was wondering if anyone else had this issue before with Dante and Vmix.
I am running Midas M32R with Dante card installed plugged into Vmix machine running Dante Virtual Sound card. I am running directly without going through network.
Midas M32R settings. Clock source - Expansion card; 48K.
Vmix sending audio to Midas and then bus back to Vmix via DVS. It will be ok for a while and then I start hearing pops and clicks. V mix sampling rate also at 48K.
Am I missing something here? Sounds like a clocking issue but clock is Expansion card, even if I switch to internal, I'm still getting clicks and pops.
Let me know what you guys think
Thanks,
I have the same problem and I can't find the solution.
Can you help me.
Thank you
