postaudio
#1 Posted : Wednesday, May 12, 2021 4:54:00 AM(UTC)
postaudio
I was wondering if anyone else had this issue before with Dante and Vmix.
I am running Midas M32R with Dante card installed plugged into Vmix machine running Dante Virtual Sound card. I am running directly without going through network.
Midas M32R settings. Clock source - Expansion card; 48K.
Vmix sending audio to Midas and then bus back to Vmix via DVS. It will be ok for a while and then I start hearing pops and clicks. V mix sampling rate also at 48K.
Am I missing something here? Sounds like a clocking issue but clock is Expansion card, even if I switch to internal, I'm still getting clicks and pops.
Let me know what you guys think
Thanks,
juanqui
#2 Posted : Monday, July 11, 2022 6:12:14 PM(UTC)
juanqui
Spain
I have the same problem and I can't find the solution.
Can you help me.
Thank you
