abtaster
#1 Posted : Monday, April 26, 2021 7:37:16 PM(UTC)
abtaster
I am redesigning all my Overlays and had to find out, the the "ShowVisbleToggel" doesn't work for bitmaps imported with the PSD import.
If I edit the documents xml by hand and replace the Rectangle/Brush part with a simple Image.Bitmap it works. But I have to do it for a lot.
Any idea how to solve this or what I am missing?
<Layer Name="testlayer" Dimensions="3840,2160,0">
<Layer.Composition>
<Composition Width="3840" Height="2160">
<Rectangle Name="SO Home Dot Red6" Dimensions="56,56,0" Location="894,967,0" DataFlags="ShowVisible">
<Rectangle.Fill>
<Brush Type="Bitmap" Color="#FFFF0000">
<Brush.Bitmap>
<Bitmap Source="e9b2b46b-4df8-4744-8aab-b60bcc586a5b\Overlay 4K.psd.20.png" />
</Brush.Bitmap>
</Brush>
</Rectangle.Fill>
<Rectangle.Stroke>
<Brush Color="#FFFFFFFF" />
</Rectangle.Stroke>
</Rectangle>
</Composition>
</Layer.Composition>
</Layer>
to
<Layer.Composition>
<Image Name="SO Home Dot Red6" Dimensions="56,56,0" Location="894,967,0" DataFlags="ShowVisible">
<Image.Bitmap>
</Image.Bitmap>
</Image>
</Composition>
</Layer>
and the Visible Togel shows up in the Title Editor in Vmix.
Henrik
