GT
Show Visible Toggle for Brush Rectangle Images doesn't work
I am redesigning all my Overlays and had to find out, the the "ShowVisbleToggel" doesn't work for bitmaps imported with the PSD import.
If I edit the documents xml by hand and replace the Rectangle/Brush part with a simple Image.Bitmap it works. But I have to do it for a lot.
Any idea how to solve this or what I am missing?
From: <Layer Name="testlayer" Dimensions="3840,2160,0"> <Layer.Composition> <Composition Width="3840" Height="2160"> <Rectangle Name="SO Home Dot Red6" Dimensions="56,56,0" Location="894,967,0" DataFlags="ShowVisible"> <Rectangle.Fill> <Brush Type="Bitmap" Color="#FFFF0000"> <Brush.Bitmap> <Bitmap Source="e9b2b46b-4df8-4744-8aab-b60bcc586a5b\Overlay 4K.psd.20.png" /> </Brush.Bitmap> </Brush> </Rectangle.Fill> <Rectangle.Stroke> <Brush Color="#FFFFFFFF" /> </Rectangle.Stroke> </Rectangle> </Composition> </Layer.Composition> </Layer>
to
<Layer Name="testlayer" Dimensions="3840,2160,0"> <Layer.Composition> <Composition Width="3840" Height="2160"> <Image Name="SO Home Dot Red6" Dimensions="56,56,0" Location="894,967,0" DataFlags="ShowVisible"> <Image.Bitmap> <Bitmap Source="e9b2b46b-4df8-4744-8aab-b60bcc586a5b\Overlay 4K.psd.20.png" /> </Image.Bitmap> </Image> </Composition> </Layer.Composition> </Layer> and the Visible Togel shows up in the Title Editor in Vmix.
Thanks Henrik
GT
