audio bus routing and multilanguage stream setup rtmp
hi everyone, please your help. i would like to use the FG audio setup to send one feed streaming to a plateforme and then to be able to have one audio mix on F bus, and the other one one G bus. like sending a local translation english bus F and other language bus G. sending a feed with FG audio select and should have one audio track on left side, and the other on right side. i check how to route all my input to the bus i want, no pb.. but when i use FG to rec or stream, the 2 channels are not separate left and right to the final destination. i rechecked all my matrice setting, bus, everything but still not working.
do you have any help?
thank you
