ALC
#1 Posted : Tuesday, April 20, 2021 2:27:42 AM(UTC)
ALC
hi everyone, please your help.
i would like to use the FG audio setup to send one feed streaming to a plateforme and then to be able to have one audio mix on F bus, and the other one one G bus.
like sending a local translation english bus F and other language bus G.
sending a feed with FG audio select and should have one audio track on left side, and the other on right side.
i check how to route all my input to the bus i want, no pb.. but when i use FG to rec or stream, the 2 channels are not separate left and right to the final destination.
i rechecked all my matrice setting, bus, everything but still not working.
do you have any help?
thank you
