Hardware Compatibility
CAN I USE MY 2009 XEON SERVERS FOR VMIX ???
Can I use any of the following servers for vMix in order to achieve great performance during HD mixing, chroma keying and virtual sets? If yes, is a GPU card essential?
HP ML310e HP ML350 G4/G3 HP ML370 G4 HP PROLIANT DL380 G6 Dell PowerEdge 2900
Joined: 8/1/2013(UTC) Posts: 32  Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
Does not matter if it is server hardware or normal hardware. It is the spec of the hardware that matters. Check out the system requirements over at http://www.vmix.com.au/supported-hardware.aspxRegarding GPU, for HD it is needed. vMix utilize the GPU for all the inputs so having one with at least 1GB is needed. Probably will find these servers wont have powerful inbuilt GPUs so you will need to get a dedicated graphics card. Jack,
