scareacon
#1 Posted : Sunday, April 4, 2021 1:32:38 PM(UTC)
scareacon
It could very well be that I haven't figured out a way to do this yet, but it would be very helpful if there was a toggle in the stream setup that enable an automatic recording of the production when you begin the stream. Other software I have used has this and it elimanates those times when, in the heat of going live, I forget to hit the record button. Thanks!
WaltG12
#2 Posted : Sunday, July 4, 2021 7:22:41 PM(UTC)
WaltG12
If you're not opposed to using a shortcut, rather than the toggle button at the bottom, to turn the stream on/off, you can pair it with another shortcut to start/stop the recording & do both simultaneously that way.
I know it's not as visual, and, thus, still not easy to remember, but it is a way to achieve the same ends.
