Joined: 8/16/2020(UTC) Posts: 7  Location: Cooperstown Thanks: 1 times
It could very well be that I haven't figured out a way to do this yet, but it would be very helpful if there was a toggle in the stream setup that enable an automatic recording of the production when you begin the stream. Other software I have used has this and it elimanates those times when, in the heat of going live, I forget to hit the record button. Thanks!
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
If you're not opposed to using a shortcut, rather than the toggle button at the bottom, to turn the stream on/off, you can pair it with another shortcut to start/stop the recording & do both simultaneously that way.
I know it's not as visual, and, thus, still not easy to remember, but it is a way to achieve the same ends.
