Keeping analog headset out active using a USB mixer.
Joined: 1/19/2013(UTC) Posts: 4   Location: South Carolina, USA Thanks: 2 times Was thanked: 2 time(s) in 1 post(s)
I use a Behringer USB mixer as primary audio source in vMix, which works fine. The analog headset (and speaker) output from the PC (Lenovo i7 laptop, Win 10)) mute whenever the USB mixer is connected so I can't hear the full program mix anywhere.
I suspect this is a windows setting issue, nothing to do with vMix, looking for a way to keep the USB mixer as an INPUT (only) and keep the laptop's analog audio OUTPUT active as the main program audio monitor. Or is there another workaround?
Thanks!
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Have you tried setting the Headphones audio output in vMix to the laptop's output instead of "Default Windows Playback Device"?
