Eric Dean Freese
#1 Posted : Wednesday, March 31, 2021 2:38:05 AM(UTC)
Eric Dean Freese
On two separate occasions, one guest out of 4 has had a glitch appear periodically during the call. In both cases, their connection has been rock solid, and we haven't lost connection. My project is 29.97, and I'm streaming and recording. This is a new issue that started this week, and I've had one of the guests on before without any issues.
Thoughts? What might I look for? Winnie glitch.mov (320kb) downloaded 9 time(s). Winnie glitch2.mov (396kb) downloaded 3 time(s). johns blip.mov (523kb) downloaded 4 time(s).
Hypohamish
#2 Posted : Wednesday, April 7, 2021 7:50:21 PM(UTC)
Hypohamish
Has there been any follow up to this? Just witnessed the same thing on 24.0.0.52
Eric Dean Freese
#3 Posted : Thursday, April 8, 2021 12:05:50 AM(UTC)
Eric Dean Freese
Here's the reply I got from tech support:
If it is only a specific caller then that would indicate it is not a vMix issue so not much we can do to solve it.
They can try a different webcam or browser.
If it is a vMix issue then you should be able to replicate it regardless of guest.
I haven't been able to get my guest to re-test his devices, though I've been told he got a new laptop since the issue. We have a show tomorrow, and I've been begging his people to schedule a test, to no avail.
Hypohamish
#4 Posted : Thursday, April 8, 2021 3:59:30 AM(UTC)
Hypohamish
Hm, I had the exact same caller last week on a different vMix system, and they had zero issues, I was on vMix 23 too.
So this is definitely not caller related, it's either software or hardware related. And given nothing has changed and I've literally only seen it since vMix 24 - it's clearly that.
Eric Dean Freese
#5 Posted : Friday, April 9, 2021 2:29:40 AM(UTC)
Eric Dean Freese
I retested my guest, same vMix system, with the only difference being the guest did did some system maintenance and cleared his caches. Clean signal, no issues.
Guest (4)
