Feature Requests
Pre Audio Metering on Audiomixer
Joined: 3/28/2021(UTC) Posts: 1  Location: Munich Was thanked: 1 time(s) in 1 post(s)
Hi as in the subject. I request the ability to set the VU Meter on the audio mixer to be set to show the input and not the output. My current problem is if I disable the master L+R audio routing, then my VU meter on the audio mixer won't show anything even if the signal is routed to some busses.  audio_image 2.PNG (99kb) downloaded 0 time(s).Thank you very much!
 1 user thanked makkesmuc for this useful post.
Joined: 2/14/2018(UTC) Posts: 11 Location: Philippines
Similarly, even if I have the Headphone matrix enabled, I get no audio in the headphones if Master channels are disabled.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
You can use Solo to pre-listen
Joined: 10/9/2019(UTC) Posts: 40  Location: Bålsta Thanks: 2 times Was thanked: 5 time(s) in 2 post(s)
+1 pre fader meters as on a hardware audio mixer
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
Feature Requests
