makkesmuc
#1 Posted : Sunday, March 28, 2021 5:58:16 PM(UTC)
makkesmuc
Germany
Hi
as in the subject.
I request the ability to set the VU Meter on the audio mixer to be set to show the input and not the output.
My current problem is if I disable the master L+R audio routing, then my VU meter on the audio mixer won't show anything even if the signal is routed to some busses.
audio_image 2.PNG (99kb) downloaded 0 time(s).
Thank you very much!
thanks 1 user thanked makkesmuc for this useful post.
stevemol on 6/15/2021(UTC)
stevemol
#2 Posted : Tuesday, June 15, 2021 3:12:04 AM(UTC)
stevemol
Similarly, even if I have the Headphone matrix enabled, I get no audio in the headphones if Master channels are disabled.
mavik
#3 Posted : Tuesday, June 15, 2021 3:24:49 AM(UTC)
mavik
You can use Solo to pre-listen
xztraz
#4 Posted : Tuesday, June 15, 2021 10:21:14 PM(UTC)
xztraz
Sweden
+1 pre fader meters as on a hardware audio mixer
jip
#5 Posted : Sunday, August 1, 2021 2:26:06 AM(UTC)
jip
Estonia
+1
