AdamMiner
#1 Posted : Tuesday, March 23, 2021 8:01:36 AM(UTC)
AdamMiner
Currently, the only way to send a Mix output to NDI/SDI/Fullscreen is by selecting the input number.
2021-03-22 16_52_39-Window.png (273kb) downloaded 0 time(s).
Would it be possible to add the "MIX" inputs as direct sources for outputs?
  • I occasionally get asked by my team why our routing is broken, and find someone dragged an input to 1 or 2 which swaps the output.
  • Also, with our ACME control surface, I have to cover the first 2 inputs with gaffing tape to remind the guys not to cut the mixes to the main mix, as the surface exposes the first 12 inputs and is not remappable.
TFMG
#2 Posted : Thursday, March 25, 2021 2:34:56 PM(UTC)
TFMG
+1
richardgatarski
#3 Posted : Thursday, March 25, 2021 7:21:04 PM(UTC)
richardgatarski
+1
I posted a similar request 3 years ago https://forums.vmix.com/...en-and-External--Outputs (no reactions, maybe because of the not-so-descriptive subject).
Our fix is to set all (used) Fullscreen, External, and Outputs sources in a script (a multifunction shortcut is also possible). And then run that script regularly when building the Preset as well as during pre-live prep. Far from elegant, but better than nothing.
