Chap
#1 Posted : Tuesday, March 23, 2021 3:30:03 AM(UTC)
Chap
Please add a red indicator to the corresponding effects when processing (Fade/Merge buttons etc) so the operator knows that the effect is still processing and do not select the next input accidentally during transition and ruin the cut. This can easily happen with long transitions.
FTB button has this blinking red indicator already.
Chap
#2 Posted : Wednesday, March 31, 2021 3:35:22 AM(UTC)
Chap
This is essential. Even ATEM Mini has this function.
YBS
#3 Posted : Wednesday, March 31, 2021 6:33:42 AM(UTC)
YBS
Antigua and Barbuda
jet
#4 Posted : Friday, April 9, 2021 5:22:19 PM(UTC)
jet
Was thanked: 29 time(s) in 27 post(s)
+1
Chap
#5 Posted : Monday, July 5, 2021 12:10:10 AM(UTC)
Chap
This is a fundamental feature and it is still not there. Please add it ASAP.
Chap
#6 Posted : Monday, July 19, 2021 11:10:10 PM(UTC)
Chap
Still not implemented :(
YBS
#7 Posted : Tuesday, July 20, 2021 4:42:08 AM(UTC)
YBS
Antigua and Barbuda
MickeyMJJ
#8 Posted : Tuesday, November 23, 2021 8:32:31 PM(UTC)
MickeyMJJ
+1
#9 Posted : Tuesday, November 23, 2021 8:51:56 PM(UTC)
Care to define "long" transition pls
Chap
#10 Posted : Thursday, November 25, 2021 12:06:17 AM(UTC)
Chap
Like 5000 ms
Chap
#11 Posted : Sunday, June 5, 2022 12:16:50 AM(UTC)
Chap
UP
#12 Posted : Sunday, June 5, 2022 12:35:00 AM(UTC)
just make a shortcut to do the transition and call a script at the same time , Check to see when the output has changed which equals transition is done .
Similar playing with activators will respond after transition is done
Chap
#13 Posted : Sunday, June 5, 2022 12:52:22 AM(UTC)
Chap
I think this is so essential feature that it should be build in to vMix.
But in the meanwhile could you kindly provide more information how to accomplish this with a script?
#14 Posted : Sunday, June 5, 2022 1:42:21 AM(UTC)
How to get a status of active input can be found in the "scripting for dummies" post by reading the value of the Active input number from the api xml. In the script you add some logic to test when that status changes (loop till changed, change will take effect when transition is finished) . what you then do is up to you like use in a title to display a notification or drive an indication on a streamdeck (can use Dynamic input to do this for example)
Image for example shows how to use a Dynamic value to use as a Activator to be shown on a streamdeck (to blink in this case)
Peter Berglund
#15 Posted : Tuesday, September 13, 2022 11:12:26 PM(UTC)
Peter Berglund
Sweden
+1
jet
#16 Posted : Sunday, October 16, 2022 7:40:34 PM(UTC)
jet
Still waiting....
jet
#17 Posted : Thursday, November 10, 2022 3:14:22 PM(UTC)
jet
Can't be that hard to implement - even OBS has it as standard. (Transition button disabled during transition)
jet
#18 Posted : Tuesday, November 15, 2022 3:39:36 AM(UTC)
jet
THANK YOU! This has been implemented in 26.0.0.20 beta!
thanks 1 user thanked jet for this useful post.
Peter Berglund on 11/16/2022(UTC)
