Feature Requests
Indicator that effect is processing
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Please add a red indicator to the corresponding effects when processing (Fade/Merge buttons etc) so the operator knows that the effect is still processing and do not select the next input accidentally during transition and ruin the cut. This can easily happen with long transitions.
FTB button has this blinking red indicator already.
This is essential. Even ATEM Mini has this function.
Joined: 11/14/2012(UTC) Posts: 409  Location: Finland Thanks: 270 times Was thanked: 40 time(s) in 38 post(s)
This is a fundamental feature and it is still not there. Please add it ASAP.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Originally Posted by: Chap  This can easily happen with long transitions.
Care to define "long" transition pls
Originally Posted by: doggy  Originally Posted by: Chap  This can easily happen with long transitions.
Care to define "long" transition pls Like 5000 ms
just make a shortcut to do the transition and call a script at the same time , Check to see when the output has changed which equals transition is done . Similar playing with activators will respond after transition is done
Originally Posted by: doggy  just make a shortcut to do the transition and call a script at the same time , Check to see when the output has changed which equals transition is done . Similar playing with activators will respond after transition is done I think this is so essential feature that it should be build in to vMix. But in the meanwhile could you kindly provide more information how to accomplish this with a script?
Originally Posted by: Chap  Originally Posted by: doggy  just make a shortcut to do the transition and call a script at the same time , Check to see when the output has changed which equals transition is done . Similar playing with activators will respond after transition is done I think this is so essential feature that it should be build in to vMix. But in the meanwhile could you kindly provide more information how to accomplish this with a script? How to get a status of active input can be found in the "scripting for dummies" post by reading the value of the Active input number from the api xml. In the script you add some logic to test when that status changes (loop till changed, change will take effect when transition is finished) . what you then do is up to you like use in a title to display a notification or drive an indication on a streamdeck (can use Dynamic input to do this for example) Image for example shows how to use a Dynamic value to use as a Activator to be shown on a streamdeck (to blink in this case)  sdblink.jpg (92kb) downloaded 1 time(s).
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
Can't be that hard to implement - even OBS has it as standard. (Transition button disabled during transition)
THANK YOU! This has been implemented in 26.0.0.20 beta!
 1 user thanked jet for this useful post.
Feature Requests
