Thremir
#1 Posted : Tuesday, March 23, 2021 1:17:52 AM(UTC)
Thremir
Custom vMix Multiviewer is ready for testing.
Check it out at:
https://multiview.multicam.media/
Source code and instructions:
https://github.com/Haavard15/vMixMultiview
I have no idea how heavy this is on your computer and I haven't tested it much myself, so test before you use it in your production.
Clarification: The multiviewer HTML page is only borders, labels and VU meters, the video is still inside vMix and video is not available through the web-browser.
Parameters
You can change the input and update interval (default 150ms and input 1) by adding the following to the URL: http://multicam.media/mu...Input=2&Interval=500
Example vMix Preset
https://multiview.multicam.media/vMixPreset/
Example multiview-layouts (vMix 24 Only)
https://multiview.multicam.media/vMixLayouts/
thanks 3 users thanked Thremir for this useful post.
Cyco on 3/26/2021(UTC), BRebels on 3/28/2021(UTC), samirbridi on 4/20/2021(UTC)
sinc747
#2 Posted : Thursday, March 25, 2021 3:16:17 PM(UTC)
sinc747
Was thanked: 203 time(s) in 169 post(s)
+1
- Tom
BRebels
#3 Posted : Sunday, March 28, 2021 2:48:28 AM(UTC)
BRebels
Looks terrific!
Im still trying to get it to work though with no luck.
fluozh
#4 Posted : Monday, March 29, 2021 4:46:30 PM(UTC)
fluozh
Japan
This is so cool!
We will try this on production for testing :)
Looks fine with my computer with vmix24!
-TA_
#5 Posted : Tuesday, March 30, 2021 9:50:22 PM(UTC)
-TA_
vMix not running on this computer ?
-Tommi
fluozh
#6 Posted : Tuesday, March 30, 2021 10:39:02 PM(UTC)
fluozh
Japan
-Tommi
Did you change API port or something?
Aecast
#7 Posted : Tuesday, April 6, 2021 7:24:26 PM(UTC)
Aecast
Was thanked: 10 time(s) in 7 post(s)
Hi Thremir,
just to clarify what yo are showing here as you are showing your Multiview Layers with a image showing input screen as video outputs on a large screen
then you mention
"Clarification: The multiviewer HTML page is only borders, labels and VU meters, the video is still inside vMix and video is not available through the web-browser."
I can see the web browser with border inputs, as mentioned. So question is why show in the picture your view with multi input being displayed as outputs.
Have you used NDI windows for this?
What are you showing on your large screen to be the working solution?
Also what is difference from the Multiview Layout built into VMIX?
Guest (8)
