Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
 3 users thanked Thremir for this useful post.
Joined: 8/2/2013(UTC) Posts: 1,113   Location: Fairhope, Alabama USA Thanks: 607 times Was thanked: 207 time(s) in 173 post(s)
Joined: 9/21/2020(UTC) Posts: 12  Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Looks terrific! Im still trying to get it to work though with no luck.
Joined: 3/18/2021(UTC) Posts: 42   Location: Tokyo Thanks: 17 times Was thanked: 13 time(s) in 10 post(s)
This is so cool! We will try this on production for testing :) Looks fine with my computer with vmix24!
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
vMix not running on this computer ?
-Tommi
Originally Posted by: -TA_  vMix not running on this computer ?
-Tommi Did you change API port or something?
Joined: 3/25/2020(UTC) Posts: 48  Location: Chichester Was thanked: 10 time(s) in 7 post(s)
Hi Thremir,
just to clarify what yo are showing here as you are showing your Multiview Layers with a image showing input screen as video outputs on a large screen then you mention
"Clarification: The multiviewer HTML page is only borders, labels and VU meters, the video is still inside vMix and video is not available through the web-browser."
I can see the web browser with border inputs, as mentioned. So question is why show in the picture your view with multi input being displayed as outputs. Have you used NDI windows for this?
What are you showing on your large screen to be the working solution? Also what is difference from the Multiview Layout built into VMIX?
