Hardware Compatibility
Preferred Wireless Tally Systems? Any cheap ones out there?
What are the preferred wireless tally systems?
Also, are there any cheap tally solutions that I might not be aware of like using the RS422 or similar ports to just add a tally light to the camera over NDI? I'm running POE and don't want to have to run another wire, so it's either wireless or through the camera. Thanks
Joined: 10/26/2020(UTC) Posts: 76  Location: Maryland Thanks: 2 times Was thanked: 26 time(s) in 20 post(s)
Forum Rank:: Member
Joined: 7/4/2016(UTC) Posts: 23  Location: Munich Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
got my Flex Tally 2 weeks ago. Large and bright lights which I can recommend. These lights have 4 brightness settings. I've tested the endurance: - @ max. brightness the lamp lasts almost 6 Hours - @ 3/4 brightness (which is perfect for indoor use) it increased to 7,5 hours
Originally Posted by: majorsky  got my Flex Tally 2 weeks ago. Large and bright lights which a can recommend. These lights have 4 brightness settings. I've tested the endurance: - @ max. brightness the lamp lasts almost 6 Hours - @ 3/4 brightness (which is perfect for indoor use) it increased to 7,5 hours At 600 bucks for 4 tallys and a base system, the definition of cheap isn't what it used to be. LOL! But yes for broadcast that is cheap. I ended up going with the M5stick and was surprised at how well they work with wireless. The cameras I have run power over USB, so it was perfect for me as I can power these up with USB and POE via the camera. Still a one-cable solution.
