goaliebob99
#1 Posted : Saturday, March 20, 2021 12:29:19 PM(UTC)
goaliebob99
What are the preferred wireless tally systems?
Also, are there any cheap tally solutions that I might not be aware of like using the RS422 or similar ports to just add a tally light to the camera over NDI? I'm running POE and don't want to have to run another wire, so it's either wireless or through the camera. Thanks
Babbit
#2 Posted : Saturday, March 20, 2021 2:32:17 PM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
I've been doing a lot of coding with Teensy boards (not wireless) and ESP32 and ESP8266 boards (both wireless) to get activators over MIDI. Fun but time consuming.
Even with all that, I'm still partial to this project:
Wireless Tally Light for $10 M5Stick-C (ESP32-Board) for vMix - Tally Light for a cheap all-in-one microcontroller with LCD panel
simond83
#3 Posted : Thursday, March 25, 2021 12:14:04 PM(UTC)
simond83
aaron804
#4 Posted : Thursday, March 25, 2021 12:25:30 PM(UTC)
aaron804
filadelfiavennesla
#5 Posted : Sunday, April 18, 2021 4:52:01 PM(UTC)
filadelfiavennesla
Norway
Also, there is Cuebi Wireless Tally Lights from https://www.cuebi.com/
majorsky
#6 Posted: : Friday, April 23, 2021 6:19:13 AM(UTC)
majorsky
got my Flex Tally 2 weeks ago.
Large and bright lights which I can recommend. These lights have 4 brightness settings.
I've tested the endurance:
- @ max. brightness the lamp lasts almost 6 Hours
- @ 3/4 brightness (which is perfect for indoor use) it increased to 7,5 hours
goaliebob99
#7 Posted : Friday, April 23, 2021 6:32:34 AM(UTC)
goaliebob99
Large and bright lights which a can recommend. These lights have 4 brightness settings.
At 600 bucks for 4 tallys and a base system, the definition of cheap isn't what it used to be. LOL! But yes for broadcast that is cheap. I ended up going with the M5stick and was surprised at how well they work with wireless. The cameras I have run power over USB, so it was perfect for me as I can power these up with USB and POE via the camera. Still a one-cable solution.
