davidcallahan
#1 Posted : Wednesday, March 17, 2021 8:21:26 PM(UTC)
davidcallahan
Hi !
Here would be the feature :
When choosing for video source, I can select only Outputs, but I'd like to send an input from every inputs I have (great when using another machine for broadcasting)
Same with audio, I can select Buses only, I'd like to be able to send another input. (great when creating a n-1 from a mixing table)
Here is a showcase I had :
I've been working with 4 Vmix call inputs lately.
I had to send the calls to an ATEM.
I needed to send to the Vmix calls a program input (from ATEM) AND an program-1 audio (from an external mixing table).
(My machine was used to send lower thirds AND video as well)
The way I used my outputs:
Out 1 : Key/Fill AND videos -> SDI
Out 2 : Call 1 -> SDI
Out 3 : Call 2 -> NDI -> NDI2SDI
Out 4 : Program (from ATEM) -> VMIX Call Sources
Fullscreen 1 : Call 3 -> HDMI2SDI
Fullscreen 2 : Call 4 -> HDMI2SDI
Audio :
Call 1 -> Bus A
Call 2 -> Bus B
Call 3 -> Bus C
Call 4 -> Bus D
Sending to Mixing table via Dante protocol
Input -> Program minus EVERY call
4 calls Audio source : headphones (So they can hear every other inputs (Calls + pgm-1)
You can see how unefficient it gets (I can't play a video AND have calls at the same time, it would loop into my mixing table (pgm-1 has the video sound))
Adding the opportunity to choose from a custom input would make it easier : I'd use only 1 FScreen (great) I'd do 4 pgm-1 audio, routing each one to each call audio sources.
Concerning video I'd just have to route the video pgm from the ATEM.
Would you think it'd be useful ?
Thanks a lot !
David
