NDI
Getting NDI source from a VM to the host OS
Hi, I tried to run OBS with the NewTek NDI plugin inside a Windows 10 VM in Oracle VirtualBox. The network of the VM was set to Network Bridge mode. In the host OS (also Windows 10 Pro) I could see the NDI source from the VM in vMix, but video/audio didn't show up in vMix although it showed up and worked well inside the NDI Tools studio monitor NDI src from the VM + vMix: https://prnt.sc/10ctjb8NDI src from the VM + NDI Studio: https://prnt.sc/10ctnllNDI src from the VM + NDI Studio ( screen recording): https://ctrlv.tv/OLQESettings of the VM: https://prnt.sc/10ctsa6 (S orry, my instalation of VirtualBox is in Czech, but you should get the idea...) Do you have any idea how to fix the NDI source not showing up in vMix? I'm still running on vMix 23.0.0.66. The newer versions didn't work well for me... Thank you for your answers!
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
I do not know if there is a NDI incompatibility between de NDI version that is used by you in OBS. With the version of NDI used in vmix
NDI
