Displaying WhatsApp messages into vMix
Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
WhatsApp desktop client logged in on a separate computer. Bring in the WhatsApp computer as an NDI input using vmix desktop capture. Crop the input to the part of WhatsApp you want to see and place it as an overlay you bring in and out when you need it. Your moderator sits on the WhatsApp computer and tells you when to bring it in our out if messages get out of hand. MyAARPMedicare
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
I have written a small PC program for this. As mentioned in fledglings post, install the WhatsApp desktop client. Then run the little program "vMix clipboard copy". Everything you mark with the mouse and send with CTRL-C into the clipboard memory, appears in my program as editable line. You can then select the entry and send it to vMix. A title example is included. Download here
 1 user thanked Peter1000 for this useful post.
Joined: 5/10/2021(UTC) Posts: 1  Location: Trujillo - La Libertad Thanks: 1 times
Originally Posted by: Peter1000  I have written a small PC program for this. As mentioned in fledglings post, install the WhatsApp desktop client. Then run the little program "vMix clipboard copy". Everything you mark with the mouse and send with CTRL-C into the clipboard memory, appears in my program as editable line. You can then select the entry and send it to vMix. A title example is included. Download here Gracias por el aporte. Hay alguna manera de que el programa copie directo a "actual text in vMix"? Me explico: abro whatsapp, copio mensaje y automáticamente cambia e título en vmix en vivo. ¿Es posible? Thanks for the program. Is there a way that the direct copy texts in a "current text in vMix"? Let me explain: I open whatsapp, I copy a message and it automatically changes the title in live title vmix. It's possible? Saludos desde SUDAMERICA - Perú.
Quote:Thanks for the program. Is there a way that the direct copy texts in a "current text in vMix"? Let me explain: I open whatsapp, I copy a message and it automatically changes the title in live title vmix. It's possible?
Saludos desde SUDAMERICA - Perú. I have added your proposal. (checkbox) Download here
Joined: 3/26/2022(UTC) Posts: 4  Location: Amsterdam Was thanked: 1 time(s) in 1 post(s)
