Feature Requests
Select Instant Replay Event By id
dear Vmix Team First The Vmix 24 Update Is Great! one thing i can see is missing in the instant Replay Api , Select An event BY ID as for now we have to do a workaround to select an event . we are using ReplayPlayEventByID but the event is plying.. and some time this workaround is not good . can we have an API Command to Just Select an event or events by ID/IDS? it will be major upgrade for API developers!
one more thing. are u considering to give an option to change in/out duration for each camera? I will explain: when u create new event u have a strip in the instant replay window with X cameras. u can change the in and out for all of the clips but not individually . i have developed a web program that creates X strips with the same in / out marks and by that i can get the power to change each angle in/out point . it's working fine but it is a bit messy...
I am requesting this feature because if we can change each angle in/out point we can have more powerful replay . the replay can be more flex.
thank u and best regards
is there any other solution we don't know because nobody votes for this feature request?
Feature Requests
