dror
#1 Posted : Thursday, February 18, 2021 6:52:39 PM(UTC)
dror
Israel
dear Vmix Team
First The Vmix 24 Update Is Great!
one thing i can see is missing in the instant Replay Api ,
Select An event BY ID
as for now we have to do a workaround to select an event .
we are using ReplayPlayEventByID
but the event is plying.. and some time this workaround is not good .
can we have an API Command to Just Select an event or events by ID/IDS?
it will be major upgrade for API developers!
one more thing.
are u considering to give an option to change in/out duration for each camera?
I will explain:
when u create new event u have a strip in the instant replay window with X cameras.
u can change the in and out for all of the clips but not individually .
i have developed a web program that creates X strips with the same in / out marks and by that i can get the power to change each angle
in/out point . it's working fine but it is a bit messy...
I am requesting this feature because if we can change each angle in/out point we can have more powerful replay .
the replay can be more flex.
thank u and best regards
xaver
#2 Posted : Thursday, February 18, 2021 8:30:52 PM(UTC)
xaver
+1
xaver
#3 Posted : Sunday, March 21, 2021 7:04:10 AM(UTC)
xaver
is there any other solution we don't know because nobody votes for this feature request?
