Joined: 2/17/2021(UTC) Posts: 18  Location: Oslo Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Has anyone tested out the Kona IP card from AJA? I figured since the Kona platform is already supported by vMix it should work, but would be happy if anyone has acctualy tested it out and can verify https://www.aja.com/products/kona-ipThanks
Joined: 6/2/2021(UTC) Views messages in topic : 3  Location: Paris
Hi Jacob, I presumed same logic concept as yours. If vMix already supported Kona platform, it will certainly should works with Kona IP. Well, actually, no... !
I will create a post on feature request regarding this topic...
C+jlblanchard, I did some more digging on this, and the Kona IP card is listed for vMix in the compatibility list here: https://www.aja.com/compatibility/konaBut have you tried? Where did things stop for you? Inputs or outputs? BR Jacob
