JacobLarsson
#1 Posted : Wednesday, February 17, 2021 10:50:40 PM(UTC)
JacobLarsson
Norway
Has anyone tested out the Kona IP card from AJA? I figured since the Kona platform is already supported by vMix it should work, but would be happy if anyone has acctualy tested it out and can verify
https://www.aja.com/products/kona-ip
C+jlblanchard
#2 Posted : Wednesday, June 2, 2021 9:56:16 PM(UTC)
C+jlblanchard
Hi Jacob,
I presumed same logic concept as yours. If vMix already supported Kona platform, it will certainly should works with Kona IP.
Well, actually, no... !
I will create a post on feature request regarding this topic...
JacobLarsson
#3 Posted : Thursday, June 3, 2021 5:29:05 PM(UTC)
JacobLarsson
Norway
C+jlblanchard,
I did some more digging on this, and the Kona IP card is listed for vMix in the compatibility list here: https://www.aja.com/compatibility/kona
But have you tried? Where did things stop for you? Inputs or outputs?
BR
Jacob
Similar Topics
Hardware compatibility with AJA KONA IP (Feature Requests)
by C+jlblanchard 6/2/2021 10:09:42 PM(UTC)
