dror
#1 Posted : Tuesday, February 16, 2021 9:48:28 PM(UTC)
dror
Rank:: Member
Israel
i was tiring to figure out two options (I don't know if the exists) In the Instant Replay API
1. Select Event - all I can see is ReplayPlayEventByID , it there a way just to select Event Without Playing it?
2. Delete Event - Is there an option to Delete An event From List With Api Command?
Best Regards
xaver
#2 Posted : Wednesday, February 17, 2021 6:47:32 AM(UTC)
xaver
you only can select First,Last,Next,Previsious Event
a shortcut for SelectByID is missing! We need it also
see
https://forums.vmix.com/...SelectEventByID-Shortcut
xaver
#3 Posted : Wednesday, February 17, 2021 7:00:29 AM(UTC)
xaver
Best Regards
in vMix 24 we will get ReplayDeleteSelectedEvent
but we still cannot select an event in an easy way
dror
#4 Posted : Wednesday, February 17, 2021 7:36:52 PM(UTC)
dror
Rank:: Member
Israel
thank you for the replay!
I have just installed the vmix 24 and I can see the delete option.
but still no option for SelectByID
my workaround for this is
ReplayPlayEventByID
the event is selected and played but not showing on program or preview,
xaver
#5 Posted : Wednesday, February 17, 2021 8:45:42 PM(UTC)
xaver
ReplayPlayEventByID
I do it in the same way, but in my opinion, it's the wrong way.
It would be much easier, if we can select an event direct without this workaround
dror
#6 Posted : Wednesday, February 17, 2021 8:53:04 PM(UTC)
dror
Rank:: Member
Israel
you are correct...
hope that they will add it in the official 24 version
xaver
#7 Posted : Wednesday, February 17, 2021 10:54:18 PM(UTC)
xaver
I hope it also, but I fear they won't
it takes 4 years to get ReplaySetAudioSource (asked for it in 2016 vor vMix17)
if they also need 4 years for this SelectByID.....
Guest (7)
