Delete, Select Instant Replay Event API
Rank:: Member
i was tiring to figure out two options (I don't know if the exists) In the Instant Replay API
1. Select Event - all I can see is ReplayPlayEventByID , it there a way just to select Event Without Playing it? 2. Delete Event - Is there an option to Delete An event From List With Api Command?
Best Regards
Originally Posted by: dror  i was tiring to figure out two options (I don't know if the exists) In the Instant Replay API
Best Regards in vMix 24 we will get ReplayDeleteSelectedEvent but we still cannot select an event in an easy way
Rank:: Member
thank you for the replay! I have just installed the vmix 24 and I can see the delete option. but still no option for SelectByID
my workaround for this is ReplayPlayEventByID
the event is selected and played but not showing on program or preview,
Originally Posted by: dror  thank you for the replay! I have just installed the vmix 24 and I can see the delete option. but still no option for SelectByID
I do it in the same way, but in my opinion, it's the wrong way. It would be much easier, if we can select an event direct without this workaround
Rank:: Member
you are correct... hope that they will add it in the official 24 version
I hope it also, but I fear they won't it takes 4 years to get ReplaySetAudioSource (asked for it in 2016 vor vMix17) if they also need 4 years for this SelectByID.....
