SilverLedge
#1 Posted : Tuesday, February 9, 2021 4:57:07 AM(UTC)
SilverLedge
I have a PC used to send scriptures to a projector. I would like to send the scriptures to another PC with vMix for online display.
What device do I need to simultaneously send to the projector and vMIX?
Thanks for the help.
SportsNetUSA.net
#2 Posted : Tuesday, February 9, 2021 6:58:05 AM(UTC)
SportsNetUSA.net
If you are using EasyWorship, it has built-in NDI capabilities.
https://support.easywors...es/24000020413-ndi-setup
If your software doesn't you could install vMix Desktop Capture on the PC with the scriptures.
https://www.vmix.com/software/download.aspx
and/or NDI Tools from NewTek to accomplish that.
SilverLedge
#3 Posted : Tuesday, February 9, 2021 7:48:25 AM(UTC)
SilverLedge
Thanks for the reply. I am using VideoPsalms.
If we install vMix on the PC with scriptures, it will be difficult for one person to do project the scriptures and pick shot from multiple cameras.
Thanks again for the reply.
SportsNetUSA.net
#4 Posted : Tuesday, February 9, 2021 9:18:08 AM(UTC)
SportsNetUSA.net
You would not be installing vMix on the Scripture PC. You would install vMix Desktop Capture on it so you could bring in the Scripture PC and VideoPsalms as an input on your vMix PC.
https://www.vmix.com/help23/inde...LocalDesktopCapture.html
You network your two computers together if they aren't already on a network which is not hard to do.
SilverLedge
#5 Posted: : Wednesday, February 10, 2021 2:24:36 AM(UTC)
SilverLedge
Ok, I see. I will try that. Thank you so very much!
SilverLedge
#6 Posted : Wednesday, February 10, 2021 2:34:24 AM(UTC)
SilverLedge
Sorry for the question, we are still on the learning curve for vMix. There a cable that connect the Scriptures PC to a projector. After I download vMix Desktop Capture on the Scriptures PC, should it be some type of cable to go to the vMix PC.
Sorry again I know this might be basic.
