I have a PC used to send scriptures to a projector. I would like to send the scriptures to another PC with vMix for online display. What device do I need to simultaneously send to the projector and vMIX?
Thanks for the help.
Thanks for the reply. I am using VideoPsalms.
If we install vMix on the PC with scriptures, it will be difficult for one person to do project the scriptures and pick shot from multiple cameras.
Thanks again for the reply.
You would not be installing vMix on the Scripture PC. You would install vMix Desktop Capture on it so you could bring in the Scripture PC and VideoPsalms as an input on your vMix PC. https://www.vmix.com/help23/inde...LocalDesktopCapture.htmlYou network your two computers together if they aren't already on a network which is not hard to do.
Ok, I see. I will try that. Thank you so very much!
Sorry for the question, we are still on the learning curve for vMix. There a cable that connect the Scriptures PC to a projector. After I download vMix Desktop Capture on the Scriptures PC, should it be some type of cable to go to the vMix PC.
Sorry again I know this might be basic.
