	Hardware Compatibility
	Hardware Configuration for 4K @ 2160p30 resolution
                We are considering installing VMIX on an HP Z4G4 Workstation with Xeon W2255 3.7GHz 10C, 64GB DDR4 2933 ECC REG, Quadro RTX4000 8GB 3DP + 1USBC, HP Z Turbo Drive M.2 512GB TLC SSD, 2x 4TB 7200 SATA Enterpise, 1x Blackmagic Decklink Quad HDMI recorder and 1 x Blackmagic Decklink Duo 2.We want to use the equipment, to manage with VMIX the audiovisual signals of a small press room where there will be 3 x 4K @ 30 PTZ cameras with NDI / HX, up to 2 laptop PCs, 1 PC for videoconferencing and 2 large 4K monitors on stage .
 Will this setup support working in 4K (2160p) @ 30Hz resolution throughout the mix? Is it possible to mix in VMIX in 1080p @ 60p resolution and configure 2 Full Screen outputs at 4K @ 30p for the monitors?
 If we want to increase by 1 or 2 external physical outputs, is it better to add internal cards such as Blacmagic Decklink Mini Monitor or another internal Nvidia card or an external card by BUS Thunderbold?
 Thank you,
 Joined: 2/1/2021(UTC) Posts: 11  Location: MilanoWas thanked: 1 time(s) in 1 post(s)
                Originally Posted by: TAZ  We are considering installing VMIX on an HP Z4G4 Workstation with Xeon W2255 3.7GHz 10C, 64GB DDR4 2933 ECC REG, Quadro RTX4000 8GB 3DP + 1USBC, HP Z Turbo Drive M.2 512GB TLC SSD, 2x 4TB 7200 SATA Enterpise, 1x Blackmagic Decklink Quad HDMI recorder and 1 x Blackmagic Decklink Duo 2.We want to use the equipment, to manage with VMIX the audiovisual signals of a small press room where there will be 3 x 4K @ 30 PTZ cameras with NDI / HX, up to 2 laptop PCs, 1 PC for videoconferencing and 2 large 4K monitors on stage .
 Thank you,
 Hi TAZ, did you complete this project? How about rtx4000 on 4K? Viceversa witch build do you have assembled? many tnx. MrBossItaly. |
