mrbossitaly
#1 Posted : Friday, February 5, 2021 3:47:06 AM(UTC)
mrbossitaly
Italy
Hi everibody,
I have completed my template for apcmini on vmix and it is working very well.
I have a second apcmini connected to the same macine.
On OS (win10) there are marked as APCMINI and APCMINI #2 but in vmix have same name.
There is a way to use tougheter but with different shortcut programmed function?
At moment they have same function as master and slave.... I wan't this...
In midi setting I see the two controller with same name and not seems to have possibility to change or apply any ID to them...
Any suggestion is appreciated.
MrBossItaly.
mrbossitaly
#2 Posted : Tuesday, February 23, 2021 6:48:34 PM(UTC)
mrbossitaly
Italy
Well,
yesterday I found the solution, with a great help from a forum member.
I'm preparing a full guide, with snapshot and tips, to explain all we did.
Stay tuned!!!
MrBossItaly.
Jamesdtl
#3 Posted : Wednesday, February 24, 2021 3:54:48 AM(UTC)
Jamesdtl
This would be awesome! I tried to get my head around it before but it seemed so complex!
giulliu
#4 Posted : Wednesday, February 24, 2021 9:08:18 AM(UTC)
giulliu
Hi, you can try with Bome Midi Translator and his Midi patch route
Regards Giulio
mrbossitaly
#5 Posted : Thursday, February 25, 2021 5:37:27 PM(UTC)
mrbossitaly
Italy
Regards Giulio
Yes, but Bome is very triky and expensive.
59€ (70$) for a controller that cost 40/50€ i belive are too much.
I use midiox with loopmidi and both are free for donation.
By the way, the guide is arriving.
I’ve to conciliate free time with work time...
Regards MrBossItaly (Antonio)
thanks 1 user thanked mrbossitaly for this useful post.
horsehead on 3/1/2021(UTC)
