2 APC Mini - 1 vMix: any experience??
Joined: 2/1/2021(UTC) Posts: 11  Location: Milano Was thanked: 1 time(s) in 1 post(s)
Hi everibody,
I have completed my template for apcmini on vmix and it is working very well.
I have a second apcmini connected to the same macine. On OS (win10) there are marked as APCMINI and APCMINI #2 but in vmix have same name. There is a way to use tougheter but with different shortcut programmed function? At moment they have same function as master and slave.... I wan't this...
In midi setting I see the two controller with same name and not seems to have possibility to change or apply any ID to them...
Any suggestion is appreciated.
MrBossItaly.
Well,
yesterday I found the solution, with a great help from a forum member.
I'm preparing a full guide, with snapshot and tips, to explain all we did.
Stay tuned!!!
MrBossItaly.
This would be awesome! I tried to get my head around it before but it seemed so complex!
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
Hi, you can try with Bome Midi Translator and his Midi patch route Regards Giulio
Originally Posted by: giulliu  Hi, you can try with Bome Midi Translator and his Midi patch route Regards Giulio Yes, but Bome is very triky and expensive. 59€ (70$) for a controller that cost 40/50€ i belive are too much. I use midiox with loopmidi and both are free for donation. By the way, the guide is arriving. I’ve to conciliate free time with work time... Regards MrBossItaly (Antonio)
 1 user thanked mrbossitaly for this useful post.
