vMix 24 Instant replay Error (due to old CPU)
 vmix24.jpg (42kb) downloaded 3 time(s).if I try to add an Instant replay in vMix24, i get the attached error in vMix 23 everthing is working C++ Runtime libraries are installed
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
This means the CPU is out of date and not supported, probably > 10 years old. vMix Replay requires a relatively modern system to work, a 2012 CPU or newer. Also Windows 10 is required as a minimum.
Time to upgrade!
Martin vMix
it's only a test machine not for production but good to know, will test it on an other pc
btw: is it possible to install 23 and 24 on the same pc without problems?
in different folder (be aware of potential differences for presets , various settings etc ) Fine if you know what one is doing , no complaining to vMix if something is amiss ;-)
