xaver
#1 Posted : Monday, February 1, 2021 3:07:20 AM(UTC)
xaver
if I try to add an Instant replay in vMix24, i get the attached error
in vMix 23 everthing is working
C++ Runtime libraries are installed
#2 Posted : Monday, February 1, 2021 12:18:43 PM(UTC)
Was thanked: 4736 time(s) in 1625 post(s)
This means the CPU is out of date and not supported, probably > 10 years old.
vMix Replay requires a relatively modern system to work, a 2012 CPU or newer.
Also Windows 10 is required as a minimum.
Time to upgrade!
eduardocfs on 2/2/2021(UTC)
xaver
#3 Posted : Monday, February 1, 2021 4:39:38 PM(UTC)
xaver
it's only a test machine
not for production
but good to know, will test it on an other pc
btw: is it possible to install 23 and 24 on the same pc without problems?
#4 Posted : Monday, February 1, 2021 8:22:57 PM(UTC)
Forum Rank:: Advanced Member
in different folder
(be aware of potential differences for presets , various settings etc )
Fine if you know what one is doing , no complaining to vMix if something is amiss ;-)
