daanvanboerdonk
#1 Posted : Sunday, January 31, 2021 8:29:13 AM(UTC)
daanvanboerdonk
Netherlands
Im using 4 cameras to livestream radio shows.
ive set up three different audio inputs for triggering the cameras when the guest or talent is speaking. This works perfectly.
I want the 4th camera (showing a studio overview) to be switched to when no one is speaking. For example when a song is being played.
How can I trigger this fourth camera to be switched to?
Thanks for the help in advance! Cheers!
JohnDelta
#2 Posted : Saturday, February 13, 2021 2:35:31 AM(UTC)
JohnDelta
Germany
so the only way to do that, that I currently know about, would be to put a trigger on your audio Input for the Musik, that each time the Audiometer on that Input reaches for example -6db it switches to Input XY.
You go to your Input Settings -> Trigger -> OnAudioDB6/12/18 -> then you choose a function -> and what Input you want to make active...
But that's just my newbie way. Probably there is also a better way that I just don't know about :)
Cheers.
thanks 1 user thanked JohnDelta for this useful post.
daanvanboerdonk on 3/8/2021(UTC)
