Trigger on audio, fallback?
Joined: 12/20/2020(UTC) Posts: 2  Location: Hlem Thanks: 1 times
Im using 4 cameras to livestream radio shows. ive set up three different audio inputs for triggering the cameras when the guest or talent is speaking. This works perfectly.
I want the 4th camera (showing a studio overview) to be switched to when no one is speaking. For example when a song is being played. How can I trigger this fourth camera to be switched to?
Thanks for the help in advance! Cheers!
Joined: 2/12/2021(UTC) Posts: 3  Location: Stuttgart Was thanked: 1 time(s) in 1 post(s)
Hi, so the only way to do that, that I currently know about, would be to put a trigger on your audio Input for the Musik, that each time the Audiometer on that Input reaches for example -6db it switches to Input XY. You go to your Input Settings -> Trigger -> OnAudioDB6/12/18 -> then you choose a function -> and what Input you want to make active...
But that's just my newbie way. Probably there is also a better way that I just don't know about :) Cheers.
 1 user thanked JohnDelta for this useful post.
