Joined: 6/13/2014(UTC) Posts: 5  Location: Sweden Was thanked: 2 time(s) in 2 post(s)
In an application I'm writing, I'm trying to parse an the XML file provided by the API, and the code I've got thus far is pretty dependent on having the XML schema known.
Would it be possible to get access to a complete XML file, containing everything there can be, or should I rewrite the XML parsing?
Best regards, Kristoffer
Are you using regular expressions to do the parsing? I've actually done some of that and it's much easier than other methods I've used. I've been using Regex in Autohotkey
I used XmlSerializer and a loader class, but I changed to using LINQ instead, which now works perfectly! Thanks anyways!
