drklump
#1 Posted : Tuesday, August 12, 2014 9:21:26 AM(UTC)
drklump
In an application I'm writing, I'm trying to parse an the XML file provided by the API, and the code I've got thus far is pretty dependent on having the XML schema known.
Would it be possible to get access to a complete XML file, containing everything there can be, or should I rewrite the XML parsing?
Best regards,
Kristoffer
madness
#2 Posted : Wednesday, August 13, 2014 9:23:21 AM(UTC)
madness
Are you using regular expressions to do the parsing? I've actually done some of that and it's much easier than other methods I've used. I've been using Regex in Autohotkey
drklump
#3 Posted : Thursday, August 14, 2014 9:02:34 AM(UTC)
drklump
I used XmlSerializer and a loader class, but I changed to using LINQ instead, which now works perfectly! Thanks anyways!
