NDI
Ndi can capture the programs as excel ,word o adobe reader
Hi my name is Alejo i am using the last version of vmix pro edition and have big problem to capture the programs as pdf adobe reader,word ,with ndi when i do try shows the program but whe i do open rhe file it seems just withe screen only does not work well same the crome web broswer can any give a had to configure a use the caprute
To make it easier for people to understand the problem exactly, perhaps you could add some screen grabs or other pictures to illustrate what's happening (or not happening)?
NDI
