Alejo1976
#1 Posted : Wednesday, January 20, 2021 3:55:16 AM(UTC)
Alejo1976
Colombia
Hi my name is Alejo i am using the last version of vmix pro edition and have big problem to capture the programs as pdf adobe reader,word ,with ndi when i do try shows the program but whe i do open rhe file it seems just withe screen only does not work well same the crome web broswer can any give a had to configure a use the caprute
zenvideo
#2 Posted : Thursday, January 21, 2021 5:59:07 AM(UTC)
zenvideo
To make it easier for people to understand the problem exactly, perhaps you could add some screen grabs or other pictures to illustrate what's happening (or not happening)?
