Jackster
#1 Posted : Saturday, August 9, 2014 3:12:18 PM(UTC)
Jackster
Just want to check before I buy anything.
DeckLink HD Extreme 2, I know it is a bit of an old card but will it work okay with vMix?
Am I right in saying it can capture HDMI and SDI at the same time, as in 2 channel capture?
vMix can use the audio in and out on the card?
Will it be okay with newer BlackMagic cards like the mini recorder, driver wise?
Thanks!
