Hardware Compatibility
BlackMagic DeckLink HD Extreme 2
Joined: 8/1/2013(UTC) Posts: 32  Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
Just want to check before I buy anything.
DeckLink HD Extreme 2, I know it is a bit of an old card but will it work okay with vMix?
Am I right in saying it can capture HDMI and SDI at the same time, as in 2 channel capture?
vMix can use the audio in and out on the card?
Will it be okay with newer BlackMagic cards like the mini recorder, driver wise?
Thanks!
