Hardware Compatibility
Error with input from BlackMagic Decklink Duo 2
Greetings everyone
I'm trying to add a camera connected via SDI on BlackMagic Decklink Duo 2 as an input on Vmix
The camera has this output: 1920x1080 50p and I've tested it working correctly with OBS (Open Broadcaster software)
When I try to add the input on Vmix however I get the following error:
"Selected Video Format is not supported by this device: bmdModelHD1080p50 Error HRESULT E_FAIL has been returned from a call to a COM component"
Is there something that I am doing wrong? I'm using the "Camera" input, selected the correct DeckLink SDI, resolution (1920x1080) and frame rate (PAL 50p)
Looking forward to hear your advice!
May I ask if you found a solution to your problem with getting SDI via Decklink Duo 2 into Vmix. I'm having great difficulty with same thing.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
there is an other little bug: if you give your inputs labels with the "BMD Desktop Video Setup", it's not allowed that the label begins with a number and it should have more than two letters costs me one hour!
