gmm920
#1 Posted : Wednesday, January 13, 2021 2:24:13 AM(UTC)
gmm920
Greetings everyone
I'm trying to add a camera connected via SDI on BlackMagic Decklink Duo 2 as an input on Vmix
The camera has this output: 1920x1080 50p and I've tested it working correctly with OBS (Open Broadcaster software)
When I try to add the input on Vmix however I get the following error:
"Selected Video Format is not supported by this device: bmdModelHD1080p50 Error HRESULT E_FAIL has been returned from a call to a COM component"
Is there something that I am doing wrong? I'm using the "Camera" input, selected the correct DeckLink SDI, resolution (1920x1080) and frame rate (PAL 50p)
Looking forward to hear your advice!
BruceJ
#2 Posted : Thursday, February 25, 2021 8:04:23 PM(UTC)
BruceJ
May I ask if you found a solution to your problem with getting SDI via Decklink Duo 2 into Vmix.
I'm having great difficulty with same thing.
dmwkr
#3 Posted : Thursday, February 25, 2021 8:53:24 PM(UTC)
dmwkr
Check the connector settings, similar to:
https://www.vmix.com/kno...k-quad2-to-be-8-channels
Then check if there is already an External Output configured in vMix on this connector you want to use as an input.
xaver
#4 Posted : Thursday, February 25, 2021 10:30:00 PM(UTC)
xaver
there is an other little bug:
if you give your inputs labels with the "BMD Desktop Video Setup", it's not allowed that the label begins with a number and it should have more than two letters
costs me one hour!
