KnucklesRedLion
#1 Posted : Tuesday, January 12, 2021 8:34:41 PM(UTC)
KnucklesRedLion
Turkey
Hello all.
as you know Adobe is killed Flash Player.
I was using this Flash/RTMP feature for work. It was flawlessly working till today. right now I keep seeing this on my tabs and I don't know how to proceed.
I checked few times. Flashplayer is still active and not uninstalled in my pc.
internet exploerer and edge sets up keeping flash content is on.
I tried different vmix versions on various pc even.
Same icon same thing.
how to fix this?
I must use this because our streams over RTMP
Ekran goruntusu 2021-01-12 132808.png (6kb) downloaded 0 time(s).
thanks 1 user thanked KnucklesRedLion for this useful post.
Daniel Huynh on 2/18/2021(UTC)
elvis55
#2 Posted : Tuesday, January 12, 2021 10:54:32 PM(UTC)
elvis55
Switzerland
NOTE: At this feature relies on Adobe Flash Player for support, a number of restrictions and limitations, particularly with audio apply.
To bring in RTMP streams, consider using the Stream input instead with the VLC dropdown option.
Stream / SRT
https://www.vmix.com/help23/index.htm?Stream.html
thanks 1 user thanked elvis55 for this useful post.
antonyrec
#3 Posted : Friday, January 15, 2021 2:17:53 PM(UTC)
antonyrec
Russian Federation
You can replace the file C:\Windows\System32\Macromed\Flash\Flash.ocx with another (without timebomb).
You need to search older Flash.ocx versions (without timebomb) in your Windows folder (it must be dated about feb 2020 and 27.5 MB file size).
thanks 1 user thanked antonyrec for this useful post.
