Flash Support is Ended. Whats gonna happen to Flash/RTMP feature?
Joined: 1/12/2021(UTC) Posts: 1  Location: Yenişehir Was thanked: 1 time(s) in 1 post(s)
Hello all. as you know Adobe is killed Flash Player. I was using this Flash/RTMP feature for work. It was flawlessly working till today. right now I keep seeing this on my tabs and I don't know how to proceed. I checked few times. Flashplayer is still active and not uninstalled in my pc. internet exploerer and edge sets up keeping flash content is on. I tried different vmix versions on various pc even. Same icon same thing. how to fix this? I must use this because our streams over RTMP  Ekran goruntusu 2021-01-12 132808.png (6kb) downloaded 0 time(s).
 1 user thanked KnucklesRedLion for this useful post.
NOTE: At this feature relies on Adobe Flash Player for support, a number of restrictions and limitations, particularly with audio apply. To bring in RTMP streams, consider using the Stream input instead with the VLC dropdown option. Stream / SRT https://www.vmix.com/help23/index.htm?Stream.html
 1 user thanked elvis55 for this useful post.
Joined: 1/15/2021(UTC) Posts: 1  Location: Ul Was thanked: 1 time(s) in 1 post(s)
You can replace the file C:\Windows\System32\Macromed\Flash\Flash.ocx with another (without timebomb). You need to search older Flash.ocx versions (without timebomb) in your Windows folder (it must be dated about feb 2020 and 27.5 MB file size).
 1 user thanked antonyrec for this useful post.
