halfpipe
#1 Posted : Tuesday, November 29, 2011 9:56:12 AM(UTC)
halfpipe
I can hear it from the hdv camera in the added input window and have followed the directions but no audible audio is recorded
#2 Posted : Tuesday, November 29, 2011 11:40:04 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
What recording format are you using AVI or MPEG?
What have you selected as the "Audio Format" in the recording setup window?
halfpipe
#3 Posted : Tuesday, November 29, 2011 6:22:28 PM(UTC)
halfpipe
MPG, AVI WMV 48K 44 nothing no sound recorded
On board sound card is doing it's thing everywhere
UserPostedImage There is indication of a sound track but no audio is present
#4 Posted : Tuesday, November 29, 2011 10:26:20 PM(UTC)
If the Recording tab is blank under the Mixer when recording it means an audio device was not correctly selected in the Recording Setup window.
Try:
1. Make sure no other program is using the Stereo Mix option.
2. Change the Audio Format to 44100 16 Bit 2 Channels instead
3. Try the AVI format option
4. Make sure speakers or headphones are plugged in to the computer and are working (you can hear audio) throughout the entire recording.
halfpipe
#5 Posted : Wednesday, November 30, 2011 10:01:13 PM(UTC)
halfpipe
By utilizing an audio source other than the stream associated with the camera's hdmi output IE the camera's analogue audio out to line in on the computer's sound card I've finally recorded an mpeg2 file containg both audio and video so progress indeed
